Check engine light ...
Old Feb 25, 2004 | 04:02 PM
audinick's Avatar
New Member
Default Check engine light ...
98 2.8qms ..i stopped really hard and my CEL came on and the engine started to idle very roughly , bouncing between 300 rpm's and 900 rpm's , i pull over stop the car, check out everything ..seems to be okay ..now every once and a while it starts to idle like that again, id say every 20 to 30 minutes for mabey like 5 minutes while in nuetral and low rpm's ...car has 75.1k and im not shure if the timing belt has been changed or not..first problem with the car in 8 months and its serviced reguarly .. any ideas ? TIA
Old Feb 25, 2004 | 04:03 PM
CMK's Avatar
CMK
Do whatever you can to find out if your timing belt has been replaced.
Old Feb 25, 2004 | 04:06 PM
audinick's Avatar
New Member
other than find service records , is there any way to confirm if it has been changed or not ?
Old Feb 25, 2004 | 04:07 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default Get the ECU scanned for codes...
many times the codes will point you to the problem. At the very least, they give you a starting point where you can then search the archives on AudiWorld to find the problem.
Also, <a href="http://www.kris-hansen.com/audi/techarticles.htm">click this</a>. Take note of the article on the Idle Air Control Valve.
Old Feb 25, 2004 | 04:08 PM
audinick's Avatar
New Member
does that apply to the 30v engines as well ?
Old Feb 25, 2004 | 04:09 PM
97A4_UT's Avatar
New Member
Default Re: other than find service records , is there any way to confirm if it has been changed or not ?
if the car has stayed in the same area, call some of the dealers in the area to c if they did the work on it.. if the car has left the area where the original owner had it, chance are you wont find out.. Try to c if any big dealers in ur area have the vin on record..
Old Feb 25, 2004 | 04:10 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default Maybe not 100% accurate, but likely >90% accurate.
You should be looking on the throttle body for a similar structure, with the same function.
Old Feb 26, 2004 | 02:18 AM
rickw's Avatar
Default No ICV on the 30 valve.
The part about checking all the vac hoses applies.
 Pouria Savadkouei
 Michael S. Palmer
3pt8 turbo
Feb 14, 2007 11:44 AM
Pete K (vegasguy)
Nov 30, 2006 09:21 AM
pentosinjunky
12v V6 Discussion
Apr 27, 2006 07:40 PM
wildaman85
Oct 12, 2005 07:52 PM
zszabo
Jun 14, 2003 10:37 PM
