Check Engine Light
2000 FWD A4
148K miles
AWD engine code
Check engine light
codes are:
1.cylinder misfire (jumps around- not consistently the same ones.)
Parts I've replaced:
MAF
Injectors
Spark plugs (have not verified the gap mmmmm should do that)
Coil Packs
Primary and secondary O2 sensors
Cleaned Carbonio Air filter
Fuel filter about 10K ago
Oh yea, It's the only B5 that I know of with an APR Stage 3+. If there are others, let's talk. The car runs perfectly but this damn check engine light will keep me from passing inspection. Thanks in advance for any suggestions.
1) the light starts flashing at you, then stays on solid
or
2) it just comes on solid
do you feel the car misfiring at all?
Have you talked to APR?
I run NGK BKR7E (Part Number 6097) every 5k with oil changes. -- which brings up the questions...what plugs, how old, and at what gap? This could be as simple as $2 spark plugs and a gap tool.
