Check engine!! please help!!!
Old Nov 1, 2004 | 07:24 AM
Quattrocket's Avatar
Default Check engine!! please help!!!
I got in my car last night and when i turned it on it started shaking and idleing very roughly. the check engine light came on and it sounded like the turbo wasnt running. there was also a plasticy burning smell coming from under the hood when i got it home. my car is a 99.5 a4 1.8TQ. any ideas of what it could be or how much it will cost???
Old Nov 1, 2004 | 07:29 AM
qfrog@work's Avatar
Senior Member
Default is the light flashing or just on
could be coil packs
could be ignition amp module.
could be any of about 7000 different codes.
pull the code and then move forward towards a solution.
Old Nov 1, 2004 | 07:43 AM
Default Re: is the light flashing or just on
the light is flashing, i am taking it in to get VAG but i would like to have an idea what is going on before i take it in.
Old Nov 1, 2004 | 08:08 AM
qfrog@work's Avatar
Senior Member
Default probably one of the 2 I mentioned
thoe are both exceptionally good at causing the engine to shake... because its firing on 3 cyl not 4.
Old Nov 1, 2004 | 11:01 AM
Default Re: probably one of the 2 I mentioned
just got back from the mechanic. VAG showed that cylinder #2 was not firing. the mechanic says that he has never seen it before. but cylinder still has compression so i hope its nothing too bad. thanks for the help. by the way, you wouldnt know how much an ignition control module goes for would you thanks.
Old Nov 1, 2004 | 03:28 PM
david9999's Avatar
STFA for the infamous cylinder 2 problem
SoCalCab04
Apr 18, 2007 11:53 AM
MLOSU
Jul 20, 2004 08:08 PM
quattrocoach
Dec 31, 2003 02:58 PM
KEVIN97A4
May 14, 2003 09:53 AM
qwerty
Oct 19, 2002 03:32 PM
