THE CHIP
Old Aug 1, 2000 | 06:48 AM
GRRLBURTON's Avatar
New Member
Default THE CHIP
alright I just purchased an Audi A4 1.8 T, and i want to know if someone could tell me a little more about what exaclty this chip thing does, because i am pretty intereted in it.thanks
Old Aug 1, 2000 | 06:51 AM
Avantadrive_Original's Avatar
Default Re: THE CHIP
Basically, your car comes with a stock ECU (Electronic Control Unit, I think) which governs the car's speed, acceleration, and other things by telling parts what to do (especially the turbo). When you upgrade your chip, you are simply telling the car to do things more aggressively. On the 1.8T, the chip dictates to the turbo booster to add more PSI.<p><A HREF="http://www.stoneleigh-manor.com/True/true.html><IMG SRC="http://www.stoneleigh-manor.com/True/king.jpg"></A>
Old Aug 1, 2000 | 06:54 AM
GRRLBURTON's Avatar
New Member
About how much horsepower does it add, does itmess up the car at all since that was not what came with the car orginally ??
Old Aug 1, 2000 | 06:58 AM
Ron_C's Avatar
Default Adds about 50 hp. Dealer must prove chip was the cause of the problem to deny service.
<p><a href="http://registry.audiworld.com/audi/registry/details.asp?car=5103"><img SRC="http://pictureposter.audiworld.com/AudiWorldPics/2000/Ron_Csig.gif" alt="Click For Registry" border="0"> </a>
-Ron, CT
('00 Silver A4 1.8TQM)
Old Aug 1, 2000 | 06:59 AM
ChrisP's Avatar
New Member
About 40 -50 HP , depending on which chip you purchase.
Old Aug 1, 2000 | 07:00 AM
EdP's Avatar
EdP
AudiWorld Uber User
Default Don't forget the gobs of torque too!
<p>
Old Aug 1, 2000 | 07:02 AM
PSS  //  Raj's Avatar
Default No. Your car comes de-tuned. Your turbo can handle PSI well above what the stock.....
ECU programming pushes through it. However, the turbo is just like any other physical object, and therefore, the harder you push it, the lesser it's lifespan. I am of the opinion that this loss in life expectancy is marginal as long as you take care of it (cooling it down after spirited driving, etc). Also, you have to run 92 or higher octane always. Otherwise, you'll get pinging, and your performance will come down.
Oh yeah, it adds anywhere from 40 to 47 hp. Add a freer flowing exhaust and you'll get another 4 to 7 hp. Add a custom air intake and that'll give you around 5 extra hp.<p>APR V.3,Remus,Eurosports,S4 17" Wheels
<a href="http://registry.audiworld.com/registry/details.asp?car=4776"> <img SRC="http://pictureposter.audiworld.com/Audiworldpics/2000/prashantsig2.jpg" Border=0> </a>
Old Aug 1, 2000 | 07:10 AM
A. P.'s Avatar
New Member
Default Well... (long)
The K03 Turbo that is in yout 1.8T is
"controlled" (actually the wastegate)
by your car's computer. The ECU upgrade
changes the fuel maps and boost settings
so that more air and fuel reach the engine
for combustion, i.e. more horsepower.
Depending on whether you get a .8 bar chip
(11-12psi of boost) or a 1 bar chip (14-15psi)
you will realistically see anywhere from 180
to 200 hp with or without a new exhaust system.
The main difference between the .8 bar chips
and the 1 bar chips is torque (a matter of
acceleration, the more torque the quicker you
get to 60, the more horsepower the higher your
top speed), as well as turbo reliability.
The K03 turbo is rated to 12psi of max boost,
and 1 bar chips "overboost" the turbo for
more power at the expense of turbo longevity.
There are plenty of A4's with 1 bar chips and
thousands of miles on the stock turbo, so who knows (I have had the Neuspeed .8 bar chip
[$170] and the GIAC 1 bar chip [$400], and personally I recommend the Neuspeed).
Either way, good luck.<p>Audi A41.8TQA
(K03 Sport, GIAC 1 bar, Remus, Intake,
HKS SS BOV, TAP cat/downpipe, etc.)
 Michael S. Palmer
GRRLBURTON's Avatar
New Member
Soit is only $500 extra , where do you find these chips and what is te best brand. how much does it cost to get installed
Sorry so many questions
Old Aug 1, 2000 | 07:13 AM
A. P.'s Avatar
New Member
Default Oh, and you could do the install, bout 10 mins or so.
<p>Audi A41.8TQA
