Chip Swapping Problems
Old Jul 27, 2000 | 02:45 PM
sparkster's Avatar
Default Chip Swapping Problems
I currently have the first version of GIAC on my 99.5 A4, I had the version30(non-surging) sent to me. I have tried swapping the chip, but my car will not start, i do not hear it recalibrating either. I then tried the stock chip and the same thing happened. I revert back to his first chip and my car recalibrates and starts up afterwards. I had tried this about 7 times on two different weekends. Anyone have suggestions on what the problem is and how i can get the new chip to work??? I contacted AWE, but i will have to drive down for him to have a look at it (said he never had this problem), but i would like to resolve it without making that extra trip.
Thanks Everyone, input is much appreciated :-) Sorry so long<p>'99.5 A4 1.8TQMS GIAC,
AWE/BORLA, ITG, UUC S.Shift
Old Jul 27, 2000 | 03:57 PM
GolfGL's Avatar
Default Maybe your other chips are fried...
Did you take care to store them in ESD safe bags or ESD foam? Handled carefully? That's the only thing I can think of. Did you leave it turned on for 2 minutes before ignition? Good luck...<p>Arun
00 1.8Tqms
Old Jul 27, 2000 | 04:16 PM
sparkster's Avatar
Default That is what i thought at first but,
I had a new one sent from AWE, nope same problem.
I followed all the directions clearly every time (expert now). Was grounded with a static braclet. could not get them to work. I did leave it turned on for 3 mintutes prior to trying to start it, cranks but doesn't start. The original GIAC chip still works though.<p>'99.5 A4 1.8TQMS GIAC,
Old Jul 27, 2000 | 05:48 PM
WarrenY's Avatar
New Member
Default Chip in the right direction?
I'm unfamiliar with the GIAC set up, but with my socketed Wett, you have to make sure to put the chip in the socket in the right direction. Did you try swapping the chip end to end in the socket? It's sounds obvious, but something to check for.
Warren
Old Jul 27, 2000 | 06:56 PM
sparkster's Avatar
Default Yes, there was a dot marked on both to line up..HELP!!!!
Old Jul 27, 2000 | 07:09 PM
sparkster's Avatar
Default PLEASE HELP ME!!!!
Old Jul 28, 2000 | 04:46 AM
GolfGL's Avatar
Default Check your sockets, soldering? Maybe cold joint, opens?
<p>Arun
00 1.8Tqms
Lowdamvanski
2.7T V6 Discussion
Dec 30, 2006 03:36 PM
jaspire
40
Sep 29, 2004 02:35 PM
rocketer5
18
Nov 12, 2003 04:33 PM
sparkster
Jul 28, 2000 10:16 AM
