Clear corner mod. To do or not to do......
Also as said before make sure to seal it all back up properly.
Last it looks MUCH better. I wasn't really sure if i should do it but now I can't belive i waited so long to do so. Now I just need the new corner bulbs. Good luck.
*EDIT*
I got thinking about the size of bit and I remembered that the first hole i drilled it was too small of a bit so it didn't take out the entire tab. Not only did i break the bit in the end i scratched the lens a little bit where the remainder of the tab was dragging. Not too bad but i can still notice.
So the size of bit is key.
