Climate Control
Old May 25, 1999 | 03:11 AM
Mark H.
Guest
Posts: n/a
Default Climate Control
I just bought a new A4 Avant and I am confused about the automatic function on the climate control. When I set the temp and the control is in auto, will the car automatically turn on the AC when needed, or do I have to set the temp and turn on the AC--after which the car will regulate the temp.<br>Thanks
Old May 25, 1999 | 03:51 AM
ALD
Guest
Posts: n/a
Default It'll do it itself
kiweohu
Old May 25, 1999 | 07:01 AM
G. Hale
Guest
Posts: n/a
If you press Auto, the air compressor will turn on all the way until the outside temp reaches around 32F.
Old May 25, 1999 | 07:30 AM
MichaelB
Guest
Posts: n/a
Default Re: Climate Control (more)
It is automatic. Furthermore, if I remember correctly, the A/C utilizes a variable load compressor. This means that the compressor is working a lot harder on a 90 degree day vs. a 70 degree day. In other words, it isn't simply an "on" and "off" scenario. When the light is on, and the A/C is working, it may be putting a heavy or light load on the engine. <p>I like this because you can leave the climate control on "Auto" and if the A/C isn't really needed that much, your performance won't be that adversely affected. On simpler systems, the compressor drains the same amount of energy from the engine regardless of how much A/C is needed to maintain the temp.<p>Mike
Thomas Rudzewick
Q5/SQ5 MKII Discussion
May 20, 2018 06:24 AM
JimKan1
Audi 100 / A6 (C4 Platform)
Feb 8, 2006 09:41 AM
Maini
Dec 13, 2002 07:58 AM
mikeyyyy
Sep 14, 2002 08:46 AM
el profesor
Dec 8, 1998 02:06 PM
