Climate Control
Old Dec 18, 2002 | 05:23 AM
Goldenrod02's Avatar
New Member
Default Climate Control
Does anyone know is there a certain Temperature that the A/C goes off? It seems to be when the setting is at 76 but does anyone know exactly at what point it goes off?
Old Dec 18, 2002 | 05:27 AM
ex-quattro PETE's Avatar
AudiWorld Expert
Default the temp setting has nothing to do with it...
As long as you're in full Auto mode, the A/C compressor will be on, regardless of what you set the CC to. However, when the outside temps drop below certain level (like freezing point, IIRC), then the A/C will never come on. At least that's what the manual says, but I could have sworn I saw it working even when outside temps were below freezing mark.
Old Dec 18, 2002 | 05:30 AM
RA121125's Avatar
Banned
Default No problem above 76 ...
I live in Scottsdale (AZ), so I can tell you that setting the A/C for the mid 80s is fairly "cold" in the summertime, and the compressor goes like normal. It isn't the temperature setting, but whether or not the interior is warmer or colder than desired.
Old Dec 18, 2002 | 05:33 AM
New Member
Default Re: the temp setting has nothing to do with it...
Ok, so then here is a stupid question. Does the AC running affect gas mileage then. I have always heard that and noticed in past cars that I got better mileage without the AC running. It seems like I am getting better mileage now that it is cold, is that fact or myth?
Old Dec 18, 2002 | 05:44 AM
AudiWorld Expert
of course, running A/C negatively affects gas mileages, especially on smaller engines.
sungkyoo115
Q5/SQ5 MKI (8R) Discussion
15
Feb 1, 2013 12:23 PM
Bruce SEA 96993
Jun 27, 2001 03:17 PM
JGC
Sep 17, 2000 07:27 PM
by
10
Oct 24, 1999 03:43 PM
el profesor
Dec 8, 1998 02:06 PM
