Climate control diagnostic problem
Old Oct 18, 2005 | 11:12 AM
gregp1962's Avatar
Default Climate control diagnostic problem
My heater is blowing cold air. I flushed the cooling system. I checked the diagnostic codes found in the tech sectionof this site.
The code it gave me is 22.1, which is "A/C Refrigerant High Pressure Switch, static open, *22.1" But, I don't understand the "A/C compressor switch off codes" on that page. Can anyone explain?
Old Oct 18, 2005 | 11:39 AM
Joey T
Guest
Posts: n/a
Default Did you bleed the cooling system?
can you verify that the heater hoses are both hot?
Old Oct 18, 2005 | 12:17 PM
gregp1962's Avatar
Default Re: Did you bleed the cooling system?
Yes, I bled the system at the heater core inlet hose. Is that the only place to bleed it?
Old Oct 18, 2005 | 12:32 PM
gregp1962's Avatar
Default What is the 22.1 code?
So, what do you do when you have a 22.1 code?
Old Oct 18, 2005 | 01:07 PM
BigEd's Avatar
Member
Yes, that's the only place (via bleeding hole). You didn't answer the question: both hoses hot?
Old Oct 31, 2005 | 10:36 AM
gregp1962's Avatar
Default Re: What is the 22.1 code?
Yes, both hoses are hot. But, both feel like they are not under pressure. Shouldn't they feel under pressure?
Old Nov 1, 2005 | 10:32 PM
gregp1962's Avatar
Default Re: Yes, that's the only place (via bleeding hole). You didn't answer the question: both hoses hot?
Yes, both hoses are hot. But, they don't feel like they're under pressure like they should when the system is up to temp.
Edward6420
A4 (B8 Platform) Discussion
Sep 3, 2012 07:38 AM
pianogrg3
May 5, 2008 07:33 AM
AudiDreamr
Aug 3, 2005 12:35 PM
Avantadrive
Aug 4, 2003 09:53 AM
tshapli
Sep 9, 2002 03:13 PM
