Code for Ignition Coil?
Old May 18, 2005 | 07:25 PM
foots's Avatar
New Member
Default Code for Ignition Coil?
My 98.5 A4 1.8TQ died. Engine light flashing, extremely bad miss (?) and rough idle. From reading other posts, seems likely a coil pack is shot.
Manual says not to drive the car with Engine light flashing, and car is missing so bad probably couldn't do it anyway.
Don't want to pay to tow the car to the dealer, but would like to read the engine code to confirm coil pack suspicion. Will code tell you which cylinder is bad? Any way to read the code without an Audi VAG tool (used to do it with a Voltmeter on a Mitsubishi). Anyone know a place to rent a VAG tool in NVA?
Appreciate any help!!
Old May 18, 2005 | 07:40 PM
JA4T's Avatar
Member
Default You do need to Vag it...
Most likely ignition control unit is the problem rather than coil pack. The coil pack problem can give the same symptoms, but is more typical on newer B5's than yours. The ignition control unit can be purchased at a much more reasonable price than the dealer at:<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&amp;engine=1.8T&amp;mod el=B5%20A4&amp;submodel=FWD&amp;category=Engine">E CS</a></li></ul>
Old May 21, 2005 | 03:52 PM
foots's Avatar
New Member
Default Determined bad ICU but now no spark... (HUCO?)
Thank you! I was able to find a tech article on the board to test the Ignition Control Unit and sure it enough - the pin for coil 2 was wide open.
Unforunately, after replacing the part (very straightforward) I have absolutely no spark. Engine turns over, but that's it.
I replaced the Bosch original with 4D0905351 (HUCO 13 8055). From reading the boards, sounds like this should work with the 98.5 1.8T, no?
I did so little to the car (other than the two screws to change the ICU), I'm thinking it must be the wrong part. At least it fired on 3 cylinders with the old part :-).
Old May 22, 2005 | 08:28 AM
foots's Avatar
New Member
Default Silcon Grease for Heat Disapation Only?
Related to the HUCO install and resulting lack of spark, could it be too much silicon grease?
The HUCO install came with a small tube of silicon grease, presumably for heat disapation. I put a *thin* layer across the bottom of the ICU. Is the bottom plate used as a grounding connection too, or just for heat disappation?
Could this be why I have no spark any more? Appreciate any help!
Old May 22, 2005 | 12:01 PM
foots's Avatar
New Member
Default Can someone save me from myself?
Ok - this shouldn't be this hard. To recap -
1) car experienced missing and flashing check engine.
2) Performed DIY test of Ignition Control Unit - found cylinder 2 was bad.
3) Purchased and installed HUCO 4D0905351 as replacement. (touched NOTHING else)
4) Tried to start car - absolutely no spark; engine turns over.
5) Reinstalled old part (expecting to see 3 of 4 cylinders fire). Same symptom as with new part; no spark!
6) Rechecked connector and pin cleanliness - all good.
Can someone suggest what's going on? Could the ECU be in an odd mode after part change? How can I troubleshoot further? I'm at a total loss.
Thank you!
Old Aug 15, 2008 | 10:39 AM
the director's Avatar
did you ever find out what happened?
AK_TTuner
May 8, 2008 07:15 PM
Kenny
Oct 27, 2007 03:14 PM
troyegly
24
Jun 10, 2007 02:28 PM
Craw_Mark
May 26, 2007 02:16 PM
Hibiscus Red S4
Sep 27, 2006 07:29 PM
