Cold Air Intake Problems
Hey guys,
I have an HPS Cold Air Intake and for a while now my engine has been idling very rough and acceleration has been lagging, to say the least (stalling out by itself even). I was looking around and after some experimentation, I noticed that when I took the filter (just the filter, not the piping) off, it idles extremely smoothly and acceleration is much better, leading me to believe that the filter (even after cleaning it and re-oiling it) is starving it of oxygen. One would think that a Cold Air Intake would IMPROVE flow, but not in this case. Does anyone have any experience with this? Thanks.
Dan
Hey guys,
Dan
To me it almost sounds like the filter being used has a dead spot right in front of the maf. If you are using a filter that mounts right to the MAF body or just in front of the maf you can NOT use a maf that has a inverted cone.
Dankrohn - Do you have a picture of the HPS kit?
To me it almost sounds like the filter being used has a dead spot right in front of the maf. If you are using a filter that mounts right to the MAF body or just in front of the maf you can NOT use a maf that has a inverted cone. .
Before you jump up and down stating the oil won't cause the MAF to die due to constrained air flow, get your argument on the same page as me. I'm not referring to the airflow. I'm referring to the contaminant (oil in the case) being sucked onto the sensor surface of the MAF. The oil doesn't make it read it wrong temporarily, it ruins the sensor
Maybe his situation is constrained airflow. But generally speaking oiled filters kill MAFs.
Dankrohn, do you have a CEL? Either way, plug into vagcom and look at MAF reading. It should read about 3 g/s at idle.
or unplug the maf and see how it runs, if the problem goes away then voila, its your maf. If the problem stays, then we can talk about other things. i also recommend fixing the issues associated with the CEL. Those codes could very well be the culprit.
I am 43 years old not 14 years old and have been been a Audi World member since 1999. lol
I have been running K&N oiled filters since I got one for my 2G Elipse back in 1995, then my A4 and both my Titans. All of them have a MAF sensor.
The only time an oiled filter is going to cause a maf to die is when the USER ends up soaking the filter with oil after they clean it. Cant exactly blame that on the filter.
Might as well just replace it with a standard flat closed end filter or one with a flat filtered end.
