Is this a common problem?
Old Mar 31, 2002 | 10:11 AM
CTAudi's Avatar
New Member
Default Is this a common problem?
My dashboard if lifting/peeling in the front. I thought it was supposed to look that way cause it was like that when I got it and didn't really pay attention till I saw the dash on a brand new GTI. Mines a 96, is this common with the newer models as well?
<img src="http://pictureposter.audiworld.com/33769/lift1.jpg">
<img src="http://pictureposter.audiworld.com/33769/lift2.jpg">
Old Mar 31, 2002 | 10:13 AM
Skene @ PES Tuning's Avatar
Elder Member
push it back down?
Old Mar 31, 2002 | 10:15 AM
HDClown's Avatar
Default should push back down under A pillar cover, even has a lip to fit under there
I'd guess it happened because it's BLACK and lots of direct sunlight during the day will cause ANY plastic to start doing funny things.
Word to wise: start using heat shield during day.
Old Mar 31, 2002 | 10:18 AM
CTAudi's Avatar
New Member
Default No good, it's like petrified and curls back up when I push it down.
It'd be a pain in the *** to get glue under it without making a big mess so I will end up living with it.
Old Mar 31, 2002 | 10:20 AM
Elder Member
Default you have to use a heat gun... to push it back down....
the sun probably baked the hell out of it... and now its tending to flex... so apply some heat and push it down.. that should work
Old Mar 31, 2002 | 11:36 AM
mdwsta4â„¢uroslut's Avatar
Member
i was going to suggest the same thing. i had the same problem w/ my very first car.
Old Mar 31, 2002 | 11:42 AM
massmole's Avatar
Junior Member
Default yes dash delamination common with 97 and older A4's...
fabrication process improved in 98+ I think.
Old Mar 31, 2002 | 01:32 PM
DrJoshSC's Avatar
Default Another '96
Mine's peeling up in the middle, but not at the A-pillar. Similar prob, though.
 Michael S. Palmer
Old Mar 31, 2002 | 02:42 PM
Dieselino (Jeff)'s Avatar
Member
I think its just a 96 thing, havent heard of a 97 yet with that problem.
BSK
Mid Atlantic Discussion
Sep 27, 2008 03:55 AM
Kriminal
Jun 30, 2006 02:25 PM
qfrog Ti20
Aug 8, 2005 02:23 PM
