control arm question
Old Mar 18, 2006 | 03:00 PM
SpeedyDTP247 CQ+UrS4's Avatar
Default control arm question
my passenger side upper control arms are loose but not clunking and the driver side upper control arms have slight play in them but not as bad as the passenger side. i didnt check the lowers because the last time i had my car at the dealer they said there good and the uppers were the ones that need to be replaced. plus i dont have any clunking noise.
my question should i replace all 8 control arms and be done with it and not have to worry about them for awhile? i all ready have replaced my tie rod ends and i have h-sport front and rear sway bars coming and front upgraded sway links and rear metal sway links.
Old Mar 18, 2006 | 03:03 PM
Justin517's Avatar
Read my post below... if you ahve over 100,000 miles on em i suggest replacing them all.
Old Mar 18, 2006 | 03:08 PM
BSK auf Arbeit's Avatar
FAQ Author
replace them all in a set and get an alignment afterwards
Old Mar 18, 2006 | 03:11 PM
Default ok. i see that ecs sells a kit for all 8 control arms and purems dont. i'm going to get the meyle
kit that ecs sells
Old Mar 18, 2006 | 03:36 PM
stesta5074's Avatar
New Member
Default Re: Read my post below... if you ahve over 100,000 miles on em i suggest replacing them all.
Yes I've replaced nearly all of them with Meyle stuff. I was shocked at how good it is! You won't be disapointed. I have some preconceived notions about non-factory aftermarket which were totally disproved! What a great product!
The steering feels BRAND new now! And my baby has 150k miles on it!
Old Mar 18, 2006 | 04:08 PM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
Bad idea. Ask qfrog why (IIRC he doesn't think highly of meyle arms).
Old Mar 18, 2006 | 04:21 PM
really?
Old Mar 18, 2006 | 04:29 PM
Keeper of the Cash
Tech Guru
Get the ones PureMS sells. Plus, it seems the general thought of ECS is bad right now...
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 18, 2006 | 04:32 PM
i only need the control arms
Old Mar 18, 2006 | 04:35 PM
Keeper of the Cash
Tech Guru
Default Ok. . .?
<ul><li><a href="http://www.purems.com/products/products.php/CA=1473/">http://www.purems.com/products/products.php/CA=1473/</a</li></ul>
