crankshaft sensor harness voltage?
Old Oct 16, 2012 | 10:16 AM
bd__14's Avatar
Default crankshaft sensor harness voltage?
96 a4 12V manual
Car cranks but does not start.
Crank sensor fault shows up with vagcom.
I tried another sensor and still the same. I get no voltage at the harness that connects to the crank sensor, with ignition on or even while cranking.
Wiring to the ECU is good and i tried a spare ECU as well.
What's the voltage that i should on that connector? And what else can i check?
thanks
Old Oct 16, 2012 | 10:28 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Fuel pump.
bd__14
12v V6 Discussion
Nov 5, 2012 05:46 AM
allroad(s) lead 2Gavin
Audi allroad
12
Aug 12, 2012 05:58 AM
RubyRedV6
12v V6 Discussion
Sep 9, 2007 05:28 PM
alpinab7
Audi Original "S" Cars
Oct 30, 2005 10:27 AM
1.8tScreemer
Feb 3, 2005 12:37 AM
