cylinder 1 misfire and cant find problem please read. long
Old Aug 9, 2004 | 03:44 PM
crashman's Avatar
New Member
Default cylinder 1 misfire and cant find problem please read. long
i have a 1999 a4 quattro. during the last week i consistantly get a cylinder one misfire code(16685)and random misfire(16684). i have switched spark plugs and coil packs to different cylinders. swapted injectors to different cylinders and ran three tanks of fuel injector cleaner through to no avail. every morning cylinder one misfire with a blinking check engine light. but quits after warm up with no miss. i did the diy check on th n122 power output stage. and it checked good. so i though maybe it had to be cold to do it. so waited till next morning and actually switched n122 inputs 5 and 4. and also switched output numbers 1 and 2. to give a different path through the n122 but still fire the right plugs. but the misfire stayed in cylinder one. it shows almost 500 misfires in a minute and 0 when warm. all wires are also good from the computer all the way to the injectors and coil packs.
Old Aug 9, 2004 | 03:53 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default compression test?
Sounds like you've touched on everything else that would come to mind.
Old Aug 9, 2004 | 08:04 PM
WJM's Avatar
WJM
Tech Guru
Default ignition amplifier... i know you said you did it...
but that would still be my guess. I'd do the check again.... I've only seen those symptoms when my IA went out.
Old Aug 10, 2004 | 04:51 AM
crashman's Avatar
New Member
Default Re: compression test?
all same on all cylinders
Old Aug 10, 2004 | 04:53 AM
crashman's Avatar
New Member
Default Re: ignition amplifier... i know you said you did it...
thats my only option will go to garage and he said he would plug in a new to try. but have to leave it over night as it only does it when cold.
Old Aug 10, 2004 | 05:29 AM
RKA's Avatar
RKA
AudiWorld Uber User
Did you do the compression test when it was cold?
Old Aug 10, 2004 | 06:59 PM
crashman's Avatar
New Member
Default Re: Did you do the compression test when it was cold?
cold and hot. made no difference.
Old Aug 10, 2004 | 07:11 PM
RKA's Avatar
RKA
AudiWorld Uber User
Default Check the vac lines on the fuel pressure regulator.
If you don't find a leak, replace the FPR and see if that helps.
The second DTC you mentioned is misfiring on all cylinders, not just #1. Something common to all four cylinders is causing this. The FPR is the first thing that comes to mind.
Old Aug 17, 2004 | 06:34 AM
crashman's Avatar
New Member
Default Re: cylinder 1 misfire and cant find problem please read. long
fixed!!!!!! broken valve spring on exhaust number 1. thanks for all the help and ideas.
Old Aug 17, 2004 | 06:47 AM
RKA's Avatar
RKA
AudiWorld Uber User
How did you get a clean compression number out of it then?
