In the dark....
Old Feb 13, 2002 | 05:16 AM
bryonblue's Avatar
Default In the dark....
Has anyone experienced frequent faulty low-beam headlights?
My dealer has replaced my low-beam bulbs twice in the past 16 months. They have now blown again. Usually one will go and then a coupla days later, the other. ...and i'm not the most popular guy around, driving at night with my high-beams on all the time!
The dealer says they got a batch of faulty bulbs, however, the originals did the same thing. Is this a common problem, like Audi's infamous glass quality, is the dealer correct, or might there be an electrical problem?
Any ideas really appreciated.
Thanks!
Bryon
Old Feb 13, 2002 | 05:22 AM
Hokie_Audi's Avatar
Sounds like an electrical problem...
Old Feb 13, 2002 | 05:26 AM
dB's Avatar
dB
Default Or else, someone's getting smudges on the glass, which burns them out quicker.
Try replacing them yourself and use some alcohol to clean the glass. Just go to Pepboys or wherever and buy some Sylvania/Osram H7 bulbs. There around $13 bucks.
Old Feb 13, 2002 | 05:29 AM
Hokie_Audi's Avatar
Default Even with that it's odd that they're popping that often...
Unless they goobered up every bulb...
Old Feb 13, 2002 | 05:32 AM
dB's Avatar
dB
Default What's your voltmeter read normally? That is odd.
Some cars appear to never burn out bulbs, while other folks burn them out all the time. Must be voltage related.
Old Feb 13, 2002 | 05:47 AM
bryonblue's Avatar
I think I run at 14 volts. Is that normal?
Old Feb 13, 2002 | 05:48 AM
bryonblue's Avatar
are you talking about the projector lens glass or the outer plastic shield?
Old Feb 13, 2002 | 07:23 AM
dB's Avatar
dB
Default Nope. The actual bulb itself. They warn not to touch the bulb glass...
Your skin oils result in hotspots on the bulb that will eventually break it. (I'm wondering if they mean shatter the bulb or just burn out the filament?? I'm not about to try it! I always clean mine off with alcohol first.
 Michael S. Palmer
Old Feb 13, 2002 | 07:24 AM
dB's Avatar
dB
Default 13.8V is the standard I believe. Sounds alright to me.
I wish I had an answer for you.
Old Feb 13, 2002 | 07:37 AM
Hokie_Audi's Avatar
Default The different surface temps caused by the oils results in a thermal gradient...
On that thin surface the gradient is enough to induce thermal shock and shatter the bulb.
diabolical
Jan 27, 2007 09:02 AM
justwentgerman212
Jul 12, 2004 06:56 AM
StormChaser404
Jan 23, 2004 04:32 AM
awesome89
Oct 31, 2002 07:14 AM
bsewall
Jan 29, 2001 04:09 PM
