DashBoard
Old Jul 10, 2004 | 09:36 PM
AudiTech07's Avatar
New Member
Default DashBoard
<center><img src="http://pictureposter.audiworld.com/65621/dashboard.jpg"></center><p>need to know how to fix this problem with a thread in the dashboard...would take it back to the place where it happened but it was in chicago and now i reside in dallas. just want to know how to lift the DB so i can tuck it back it without cutting the piece off or anything along those same lines. thanks
Old Jul 10, 2004 | 09:40 PM
EuropaVin's Avatar
Default Re: DashBoard
I had that same problem when i had a 98.5. Couldn't figure it out.
Good Luck.
Old Jul 10, 2004 | 09:41 PM
ek mike's Avatar
Mr. Solid Citizen
Default Me too.
I just tucked it all back in with a screwdriver.
Old Jul 10, 2004 | 09:46 PM
xAxQUA4TTROxNx's Avatar
New Member
mee tooo...i just cut a little with a razor and tuck the rest back w/ flat head
Old Jul 10, 2004 | 09:49 PM
AudiTech07's Avatar
New Member
Default yeah tried tucking it back in with a flathead....
but put a mark onto it so want to avoid those blemishs if possible. is there a tech article that shows how to take the dashboard off?
Old Jul 10, 2004 | 09:50 PM
ek mike's Avatar
Mr. Solid Citizen
Default You don't need to remove the dashboard.
Look at SPP instructions for dash mounted boost gauge. That will tell you how to remove center vent section.
Old Jul 10, 2004 | 09:58 PM
Audi juice's Avatar
I just used a credit card to tuck it back in.
Old Jul 10, 2004 | 10:00 PM
AudiTech07's Avatar
New Member
Default Re: You don't need to remove the dashboard.
show the link please...
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 10, 2004 | 10:14 PM
Xel's Avatar
Xel
Member
which credit card works the best?
Old Jul 10, 2004 | 10:21 PM
Zodiak's Avatar
Default I'll just tell you how to do it
take a credit card, and slide it into the left side of the middle vent, pull on the right side of the middle vent with your hand (if you can't get a good grip, run some wire or a metal coat hanger through and back out of the vents (like a sideways U with the tips facing you) and pull the vent out. The center housing (that holds all 3 vents) just slides right out, reach in and pull on it. Be patient it will come out. then you can tuck that thread back in. The middle vent you took out just pops right back on, but make sure you don't lose the little metal piece and don't break the vent, they are $$$
