Did I get the wrong CD bracket?
Old Nov 3, 1998 | 05:12 PM
Brian
Guest
Posts: n/a
Default Did I get the wrong CD bracket?
I just got my CD changer + adapter for my 97<br>A4, stock radio. But I think that I got the wrong mount, because the FAQ talks about a horizontal<br>mounting bracket, but the one I got is vertical<br>mount with with carpeting that fits in the<br>tire jack area, part # 8D5 035 113. That kind<br>of sounds like the mount bracket for the 98.5<br>A4 changer, isn't it? Do I have the wrong mount?<p>2 other questions, I didn't get any screws or<br>instructions either. a) which screw is the <br>shipping screw? and b) what size screw do I need<br>for bolting it into the (correct) bracket?<p>97 A4 1.8T Q AT<p>
Old Nov 3, 1998 | 05:34 PM
Tony
Guest
Posts: n/a
Turn the bracket around !!!!
Old Nov 4, 1998 | 09:02 AM
Bert
Guest
Posts: n/a
Default Maybe bad news... read on
If you did in fact got a CD changer AND an adapter to make it work, chances are you got a CD changer for the newer Concert radio. On the 97 A4's, the Delta radio was used, and I don't think an adapter is available for any non Audi CD player. The bracket that you recieved with the CD changer further indicates that you may have gotten an incorrect CD player. On the factory Audi CD player for the Delta radio, the bracket is just a simple piece of metal the bolts to the bottom of the rear shelf.<p>HTH<br>Bert
Old Nov 4, 1998 | 09:31 AM
Brian
Guest
Posts: n/a
Default Re: Maybe bad news... read on
Thanks Bert,<p> That's what I thought, I thought that the 97 Changer bracket was different than the multi<br>compartment unit that fits in the tire jack area.<p> But I'm fairly certain that I got the right CD changer though, I looked through the archives<br>and saw Steve S's post for the part number, and he listed the 97 Delta changer as<br>4D0-035-111, which is the one that I got. I didn't get any adapters, only the changer +<br>wheel well mounting box.<p>Brian<br>97 1.8T AT Sport<br>
Old Nov 4, 1998 | 10:41 AM
Bert
Guest
Posts: n/a
Default I guess you have 2 options...
Brian, <p>I guess you are now face with the dilemma of either using the the mounting box in hand, or trading it in for the mounting bracket. Let me state some pro's and con's I've seen with my mounting bracket. <br>a. The bracket does get the CD changer off of the bottom of the trunk but it is now vulnerable to getting hit when you are a little careless with loading things in the trunk. <br>b. If the bolts used to hold the bracket in place do loosen and backout, there is more distance for the CD changer to drop and potentially be damaged.<br>c. Getting it off the trunk bottom does give you a little more usable trunk space. (I've never had that much stuff in my trunk this would have been an issue.)<p>Final note - If I had an option when bought my CD changer, I would have gotten the mounting box instead. But I would probably find minor annoyances with that too.<p>Please take your gain of salt with this post.<br>Bert
eurospeed944
Oct 24, 2007 05:28 PM
Jim II
Apr 16, 2005 07:07 AM
Audiargent
Oct 2, 2002 12:43 PM
tek2582
Sep 5, 2001 03:35 AM
Auditude
Apr 7, 2000 06:40 AM
