Disabling headlight washers
Old Jan 6, 2009 | 06:46 AM
driveslikegranny's Avatar
Default Disabling headlight washers
My driver side headlight washer was sticking in the up position. In the 7 years of ownership I have yet to use the headlight washer on purpose. After reading posts about people loosing the washer cap due to activating the washers at highway speed, I decided it was time to disable them. There were some discussion about how to do this on the forum but I could not find a working link to the exact instruction. After some time attempting to decipher the Bentley Manual electrical wiring diagram this is what I did:
1) remove knee bolster
2) remove big brown relay 389
<img src="http://pictureposter.audiworld.com/22981/washerrelay.jpg">
3) remove the relay socket from the carrier plate by lifting 4 small tabs. The socket slides out from the back.
<img src="http://pictureposter.audiworld.com/22981/washerrelaysocket.jpg">
4) cut the fat red/violet wire and insulate the exposed ends with electrical tape. You can also wire a switch connecting the two ends of the red/violet wire you just cut mount it somewhere to allow enable/disable the headlight washers.
Done!
Old Jan 6, 2009 | 06:48 AM
pac1085's Avatar
you could just unplug the pump too...
Old Jan 6, 2009 | 06:50 AM
velosouljah's Avatar
:Note: they can be *adjusted* so they don't stick in the up position. LOL....
Old Jan 6, 2009 | 06:58 AM
MrGoodbytes's Avatar
^^^ This is what I did. Took 2 minutes.
Old Jan 6, 2009 | 07:09 AM
ZB4rngs's Avatar
Default So if you were to put .....
Say 12VDC to that wire the headlight washer pump would work alone? If so I'm thinkin a momentary push button switch hehe.
Old Jan 6, 2009 | 07:11 AM
ZB4rngs's Avatar
Default Re: :Note: they can be *adjusted* so they don't stick in the up position. LOL....
Can they be adjusted to spray out to the side? A people soaker lol lol
Old Jan 6, 2009 | 07:22 AM
But I still don't want them activated when moving at highway speed.
Old Jan 6, 2009 | 07:25 AM
but I would have to somehow seal up the electrical connectors to the pump
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 6, 2009 | 07:34 AM
4Rings::G2 boosted::'s Avatar
Banned
better yet, remove the pump and seal the hole
Old Jan 6, 2009 | 07:37 AM
I didn't think of that but yeah, it should work.
