does anyone know conversion from MBAR to psi?
Old Oct 27, 2003 | 05:13 PM
Tongpo~Dr. Evil's Avatar
Member
Default does anyone know conversion from MBAR to psi?
i logged a few runs tonight with vag-com attached on block 115. it spit out raw data, i wanna change the mbars to PSI but don't know the conversion...
Old Oct 27, 2003 | 05:17 PM
mchang's Avatar
Default google: 1 mbar to psi
built in conversion r0x
Old Oct 27, 2003 | 05:18 PM
unregistered user's Avatar
New Member
or stfa even
Old Oct 27, 2003 | 05:20 PM
Member
Default i did STFA-
there's too many opinions in there as to which is best.
Old Oct 27, 2003 | 05:21 PM
Member
would rather a formula since it's a log with over 2000 rows of data...
Old Oct 27, 2003 | 05:25 PM
mchang's Avatar
Default that is your formula
1 millibar = 0.0145037738 pounds per square inch
multiply your millibar by 0.0145037738 to get psi.
Old Oct 27, 2003 | 05:32 PM
homeslice's Avatar
Default Try this
Mbar - 1013 divided by 1000 = Bar
Bar x 14.5 = psi
Old Oct 27, 2003 | 05:36 PM
Member
Default and there-in lies the problem...
spec. actual
1510 1000
1790 1120
1880 1260
1890 1600
1840 1870
1740 1770
1620 1620
990 1590
if you plug in the formula you had up there, we're looking at
21.90069844 14.5037738
25.9617551 16.24422666
27.26709474 18.27475499
27.41213248 23.20603808
26.68694379 27.12205701
25.23656641 25.67167963
23.49611356 23.49611356
14.35873606 23.06100034
as the PSI conversion...hmm...don't think i'm getting 27psi off an apr chip...see my dilemma with conversions?!?!?
on the other hand, i found another formula
(mBar-1013.23)/1000*14.50377
which makes the numbers more feasible, but it would mean i'm either having a boost leak or i'm just running very low boost- max outta all my runs with that conv. factor is 13.01psi....max requested 13.15....
Old Oct 27, 2003 | 05:39 PM
Member
yeah, that's the other forumla i tried- thanks for giving help =)
Old Oct 27, 2003 | 05:42 PM
lost in beer country's Avatar
Default mbar x 0.0145=psi but as QuattroForge said you will have to take out
1000 mbar give or take for your altitude.
