DOH - Re-assembling the head
Can someone look up in the manual for the correct torque and does anyone have a core head in the DC area that I can borrow 2 bolts from?
I won't be able to get replacements until Wednesday. Did I say - DOH?
<img src="http://www.turn2usa.com/images/audi_a4/headgasket/DSCN0508.jpg">
<img src="http://www.turn2usa.com/images/audi_a4/headgasket/DSCN0509.jpg">
<img src="http://www.turn2usa.com/images/audi_a4/headgasket/DSCN0523.jpg">
<img src="http://www.turn2usa.com/images/audi_a4/headgasket/DSCN0530.jpg">
<img src="http://www.turn2usa.com/images/audi_a4/headgasket/DSCN0531.jpg">
Component
Tightening torques
Cylinder head cover to cylinder head
10 Nm (7 ft lb)
Ignition coils to cylinder head cover
10 Nm (7 ft lb)
Crankcase ventilation line to cylinder head cover
10 Nm (7 ft lb)
_________________________________________________
- Insert cylinder head bolts and hand tighten
- Tighten cylinder head bolts in sequential order, in two stages:
Step 1 = 60 Nm (44 ft lb)
Step 2 = additional 1/2 turn using rigid wrench (180 is equivalent to two 90turns)
<img src="http://pictureposter.audiworld.com/38300/getimage.jpg">
If u do, let us know, what's the compression ration now.
I had my 86 8v scirocco decked. Well, the machine shop took a little too much off. The engine gained much pep...However, I had to use 93 at ALL times. Anything lower, and it sounded like a diesel....
Good luck,
Get us some more close up pics..
DG
