Dome Light Timer
Old Apr 21, 2007 | 04:19 PM
ajg617's Avatar
Audiworld Senior Member
Default Dome Light Timer
Hello all,
Is there a separate relay timer for the dome lights? Mine are stuck on all of the time unless I manually switch the dome units off. Doors activate under dash lights fine but will not turn domes off. Locking car won't turn them off either.
Thanks,
AJG617
Old Apr 21, 2007 | 04:26 PM
JAFO's Avatar
you do know the switch is three position.
Old Apr 21, 2007 | 04:29 PM
n0yxl's Avatar
Default He knows that part already.
"Mine are stuck on all of the time unless I manually switch the dome units off"
Old Apr 21, 2007 | 04:51 PM
JAFO's Avatar
do you windows still operate after they should have timed out like the interior lights?
Old Apr 21, 2007 | 05:14 PM
ajg617's Avatar
Default Re: do you windows still operate after they should have timed out like the interior lights?
Yup, windows remain active until any door is opened.
Old Apr 21, 2007 | 05:25 PM
Yippers®'s Avatar
Member
Default All these items appear to route thru the central locking control unit ..
Windows, reading light control module, footwell lights, door lamps ....
Old Apr 21, 2007 | 05:35 PM
ajg617's Avatar
That's what I'm afraid of - is there a procedure for resetting it?
Old Apr 21, 2007 | 06:28 PM
Yippers®'s Avatar
Member
Not that I've run into.
 Michael S. Palmer
Old Apr 21, 2007 | 07:13 PM
Im@wesome~ out!'s Avatar
Default did you wire somethign to the fuse?
its possible that it's completeing the connection
Old Apr 21, 2007 | 07:27 PM
ajg617's Avatar
Default Haven't touched the fuse panel...stock car
Interesting though, now that I think about it the radio lights are out as well. Maybe coincidence but I think they time out as the windows should??
