Driver-side door lock issue
Old Jan 22, 2007 | 10:44 AM
tipo158's Avatar
New Member
Default Driver-side door lock issue
When I lock the car with the key in the driver side door, it just locks the driver side door. When I lock the car with the key in the passenger side door, it locks all locks and arms the alarm. The driver side lock used to do the right thing until one day when I felt something come loose or break when I was locking the car.
I initially thought that it was in the door lock and took that out this weekend and figured out that the problem wasn't there.
I now suspect what is called the "coupling plate" in the Bentley manual (page T57-9). It rotates with the lock tumbler and has a toothed gear that engages with a microswitch. However, I can't find it in the wiring schematic for the central locking system and I would like to confirm that this is what I should be looking at before tearing the door apart again.
Anyone here have experience in this area? For what it is worth, my car is a late 97.
alan
Old Jan 22, 2007 | 11:12 AM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
You will need to replace the microswitch itself. 8D0-959-985 costs $88.12 MSRP.
Old Jan 22, 2007 | 01:33 PM
tipo158's Avatar
New Member
Do you know where the microswitch is in the schematics?
Old Jan 22, 2007 | 02:16 PM
Keeper of the Cash
Tech Guru
No, I looked it up through the parts catalog.
Old Jan 22, 2007 | 05:15 PM
tipo158's Avatar
New Member
Default Are you sure on the part no?
Looked at ETKA and the part number looks like the door handle microswitch. In addition to the latch closed microswitch and the coupler lock cylinder position microswitch, there is also one that indicates that door handle has been lifted.
Old Jan 22, 2007 | 05:22 PM
Keeper of the Cash
Tech Guru
Default Are you a n00b who has 27 posts? Do you do hundreds of part number lookups a month?
Then you tell me from this diagram below what part <i>it is</i>.
<img src="http://i7.photobucket.com/albums/y293/FastA4Turbo/audi/97microswitch.jpg">
Old Jan 22, 2007 | 05:31 PM
tipo158's Avatar
New Member
Default Guess I know better that question your ETKA studliness
My copy of ETKA has a different part number (893-959-985A) and different part number reference (16A). I like your part number better; it is cheaper.
Old Jan 22, 2007 | 05:36 PM
Keeper of the Cash
Tech Guru
Well, you did look your number up under the wrong VIN range. 8D-T is the oldest and not a late '97.
Old Jan 22, 2007 | 06:09 PM
tipo158's Avatar
New Member
Default The Model, Year, MG, SG and Illustration fields are the same, but the illustration and parts list ..
... are different.
Old Jan 22, 2007 | 06:40 PM
Keeper of the Cash
Tech Guru
Man, you are running an oooold version then. Mine's old as it is.
20VTURBOA4
A4 (B7 Platform) Discussion
Dec 9, 2019 07:42 PM
tanchelli
Aug 31, 2016 05:07 PM
smarty666
Q5/SQ5 MKI (8R) Discussion
Nov 2, 2015 04:54 AM
nbvolks
10
Nov 1, 2007 03:34 PM
OOOO_Circus
Dec 18, 2006 06:52 AM
