E-Brake Adjust
Old Jan 4, 2011 | 06:41 PM
FishMan's Avatar
Default E-Brake Adjust
I just replaced my rear calipers, rotors, and pads. I bled the system and my brakes work great but my e-brake engages toward the end of its travel; it used to engage a lot sooner. Is there an adjustment, and if so, how do I do it?
Old Jan 4, 2011 | 09:20 PM
turbo510's Avatar
The cable can be adjusted but if you just replaced the calipers, with use they should adjust themselves.
Old Jan 5, 2011 | 05:09 AM
moloveshisaudi1254's Avatar
What turbo510 said. I believe to adjust the cable only you have to remove your rear ash tray and possibly the center arm rest. There is a nut under there that adjusts the handbrake cable.
Old Jan 5, 2011 | 05:23 AM
Default Never mind what I said.
Never mind what I said I mis-spoke. You have to remove the arm rest and use a screwdriver to hold the handbrake in place. The parking brake adjusting components are in the tunnel for FWD and in front of the lower rear control arm for quattro vehicles. You will need roughly 13mm open end wrench to hold the nut and turn the other adjusting nut by hand. Hope that helps. As soon as I can find the pdf's I will try to post clearer instructions.
Old Jan 5, 2011 | 09:18 AM
FishMan's Avatar
Thanks, if you could send the pdf, that would be great.
Old Jan 5, 2011 | 05:19 PM
I can email the pdf's as an attachment. Can you provide me your email address?
Old Jan 6, 2011 | 02:13 AM
levente's Avatar
also can be adjusted underneath the car you should see it ( might be rusted ) around the lower control arm
gruvenparts.com
Oct 11, 2016 04:47 AM
ex-quattro PETE
Q5/SQ5 MKI (8R) Discussion
Sep 29, 2015 03:45 AM
mxp
Sep 26, 2015 10:15 AM
legerrej
Sep 25, 2015 08:43 PM
cobrar97
Sep 25, 2015 01:17 PM
