e-code help needed...it's a mechanical problem.
Old Oct 31, 2001 | 06:01 PM
dbtong's Avatar
Default e-code help needed...it's a mechanical problem.
problem is with the driver side housing. inside, towards the side closest to center of car and attached to the bottom edge of the housing is a white piece with a ball on one end. this ball SHOULD be clipped into a socket/arm that is connected to the back of the high-beam reflector. mine has come out somehow and i can't figure how to get it back in there. doesn't seem to be enough play for me to clip it back in. anyone? without it being clipped in, the entire reflector is not secure and it's going to shake a lot.
Old Oct 31, 2001 | 06:08 PM
shehatezme's Avatar
WOW! Nice E-Codes, sorry I cannot help cause I dont have one.
Old Oct 31, 2001 | 06:14 PM
Bimmer Love's Avatar
Member
it won't aim properly without it... just gotta take the light off and push hard.
Old Oct 31, 2001 | 06:15 PM
siberian's Avatar
Default I had this happen to me..... it can be snapped back in...
I over-adjusted it once and caused that ball to pop out of it's socket. Obviously you have to remove the housing from the car. Then take the back cover off and you will need to finagle it a little. It's been a long time since I did it, and I can't recall what method or tools I used... but after wrestling with it awhile I did manage to snap it back in.
Old Oct 31, 2001 | 06:17 PM
dbtong's Avatar
Default i was hoping there was a 'correct' way...
i'm gonna pray i don't break anything trying to force it back in. did you force it straight into the socket or from the bottom...which looks like it's more open but is harder to get to.
Old Oct 31, 2001 | 06:21 PM
Member
Default dude, I just kept punching and cursing till all of a sudden it was in there...
it's was a bitch to do, and I thought I screwed
up, but mine were fine till the fateful day I
totalled Tank.
Old Oct 31, 2001 | 06:24 PM
dbtong's Avatar
thanks...i hope you don't see me posting, "driver side e-code needed" tomorrow.
Old Oct 31, 2001 | 06:39 PM
Senior Member
Default I just did mine this past week and I had to take it off in order to put in the
autolevelling motor so I know how to do it. But it's hard to explain it in typed words. email me and I'll give you my number if you want to call and I can walk you through it.
 Michael S. Palmer
Old Oct 31, 2001 | 06:40 PM
dbtong's Avatar
Default wanna give it a shot on AIM?
sjm2fs
Old Oct 31, 2001 | 09:51 PM
dbtong's Avatar
Default PROB SOLVED...thanks FOO FHTR.
like he told me...kinda hard to explain in written form. if anyone else needs help, just holla!
Plutar
9
Nov 20, 2005 10:01 AM
BlownHeadlight
Oct 3, 2004 04:58 AM
Boggy
Jun 14, 2004 01:21 AM
carl [i has type-S]
Oct 3, 2002 04:11 AM
MatthewZ
Dec 25, 2001 01:58 PM
