ecode corner plug installation ?
Old Dec 9, 2002 | 06:13 AM
sandwood's Avatar
New Member
Default ecode corner plug installation ?
I recently got the ecodes from ECS and discovered that the 2 pin plug for the corner lights does not match the car's 3 pin plug - duh. ECS Tuning says I can just snap off the third pin on the car's plug and then the ecode 2 pin plug will fit in perfectly. Has anyone else done it this way? Any issues? Thanks
Old Dec 9, 2002 | 06:17 AM
HDClown's Avatar
Default Use the BLACK plugs from your US Spec housings
They DO fit into the ecodes. You don't need to break any pins off anything. You put 2 of the 3 prings into the ecode and you can turn the plug just slightly enough so the 3rd pin slides in, since it's soft plastic.
Old Dec 9, 2002 | 06:24 AM
sandwood's Avatar
New Member
I'm using silvervision bulbs so I need to use the white euro plug...
Old Dec 9, 2002 | 06:26 AM
HDClown's Avatar
Default Oh.. well then you have to do what ECS says
Or you can cut the US Spec connector end OFF, get a Euro spec one and solder it on.
Old Dec 9, 2002 | 06:43 AM
'Bahn Burner's Avatar
Default Aren't those single filament housings? You'll only be able to use them as turn signals...
...I didn't like that, as you lose the amber parking lights...doesn't seem as safe with just city lights & turn signals only.
Old Dec 9, 2002 | 06:46 AM
sandwood's Avatar
New Member
yep. doesn't bother me as long as I have city lights - can always turn on headlights
CTA4AVANT
Nov 18, 2007 06:29 PM
markbradford
Nov 26, 2002 12:27 PM
Wakeboarder_Boy
Sep 7, 2002 12:46 PM
Audilard
Aug 30, 2002 06:04 PM
cdmilton
Dec 29, 2001 04:35 PM
