ECT SENSOR
Old Feb 12, 2003 | 06:04 AM
vincenzo's Avatar
New Member
Default ECT SENSOR
Since I've changed my ECT sensor, my dash temperature gage does not go over 65 degrees. Has anyone ever experienced this issue. Was it caused by the fact that I removed the ECT sensor?
Old Feb 12, 2003 | 06:40 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Do you mean the outside temp? Or the coolant temp?
Old Feb 12, 2003 | 06:58 AM
vincenzo's Avatar
New Member
Default Re: Do you mean the outside temp? Or the coolant temp?
Hi again Kris. It's been a while. Actually, it is the collant temperature. When I pop out the ECT sensor to change it, some pressure and coolant came out. I then refilled the coolant liquid tank. Where did I go wrong?
Old Feb 12, 2003 | 07:19 AM
Head Cat Herder
25 Year Member
Do you get heat out of the dash vents?
Old Feb 12, 2003 | 07:28 AM
vincenzo's Avatar
New Member
Default Re: Do you get heat out of the dash vents?
Since I've changed the ECT sensor, it is not as warm. When I get to a stop sign, you could feel that the temperature inside the cabine goes down. If I stay on Park or Neutral for a long time, the temperature(Engine coolant gage)goes up but as soon as I go for a drive, she drops back to as low as 65 degrees.
Old Feb 12, 2003 | 07:50 AM
Head Cat Herder
25 Year Member
Default Sounds like maybe you have an airpocket. Try to bleed the system..
Do you have the Bentley manual?
Old Feb 12, 2003 | 09:36 AM
vincenzo's Avatar
New Member
Default Re: Sounds like maybe you have an airpocket. Try to bleed the system..
I do.
Norbert
Aug 22, 2005 11:25 AM
Arcteryx::Stock Rods
Jul 28, 2004 07:59 PM
Hoodini
Feb 16, 2003 10:00 AM
JimmY@RojoCollisioN
Sep 9, 2002 12:36 PM
plexxx
Feb 4, 2002 04:21 PM
