ECU
Old Apr 10, 1999 | 10:09 AM
Mike
Guest
Posts: n/a
Default ECU
Can anyone tell me if the ECU's for 98 and 99 1.8ts the same? Will a 98 ECU work with my 99 1.8t?
Old Apr 10, 1999 | 10:20 AM
Willow
Guest
Posts: n/a
Default ECU 99.9% the same but
If you went to an automatic from a 5 speed manual or vice versa it will be different. 5 speed to 5 speed no difference.
Old Apr 10, 1999 | 01:39 PM
CharlieG
Guest
Posts: n/a
Default Transmission designation is "coded" on 98's and can be changed (more)
I just went through this with a spare ECU I picked up for my 98.5 A4. I'm not entirely sure that it applies to the 99 but here's what I found out:<p> The spare came from an A4 w/automatic transmission and mine's a manual. It worked fine when I installed it for check-out when I received it but the check engine light lit on the second start (ran perfectly otherwise). I was informed that this is beause of the tranmission differences and that it can be corrected (ECU re-coded for a manual transmission) with the VAG tool (or equivalent). I sent the ECU to Garrett Lim for chipping and he agreed to re-code it for a manual (actually Todd at Air & Water is doing the re-coding). <p> More details to follow when I get the ECU back and have a chance to "evaluate" it.<p>Charlie (1.8TQMS 9700 miles)
ll euroa4 ll
Aug 22, 2007 04:20 PM
JBSMOOTH
VAG-COM Discussion
Apr 13, 2005 07:14 AM
R1ce
Oct 16, 2002 11:26 AM
98A4Turbo
Dec 27, 2001 12:01 PM
Bill Gucker
Jul 23, 1999 12:54 PM
