ECU problem
Old May 15, 2002 | 02:37 PM
Dirty Dingo's Avatar
New Member
Default ECU problem
I took out my ECU when my car was being painted. And when I put it back in the car will not start. It was out for about a month, and I followe the instruction for re0installing the ECU under the Tech report. Does anyone have any idea why my car will not start? It turns on, and all the gauges come on, but there is no spark. Will a Vag tool find the problem? Could the ECU be fried? Any ideas?
Old May 15, 2002 | 02:38 PM
Sourdough Josh's Avatar
Sounds more like your battery is dead.
Old May 15, 2002 | 02:42 PM
New Member
No, the battery has been on a charger, and it's putting power out.
Old May 15, 2002 | 02:48 PM
Default That's very odd. You could certainly try looking for codes with a VAG. Have you tried a jump or
another battery just in case? I don't want to push, but it's just that those are the EXACT symptoms of a low battery.
Yeah, I'd say if you've verified it's not the battery, try a VAG next and look for codes.
Old May 15, 2002 | 02:51 PM
RickM's Avatar
AudiWorld Uber User
Power for the dash isn't anything like the power needed to crank. Hearing a "click" when you try?
Sal R.'s Avatar
Might have a faulty transmission switch.
Old May 15, 2002 | 02:53 PM
In the past, when my battery has been really dead, I don't even get the click, FWIW.
Old May 15, 2002 | 03:00 PM
New Member
It's turning over and I can smell gas, but there is not any spark
 Michael S. Palmer
Old May 15, 2002 | 03:02 PM
New Member
I think I'll try another battery and try to run a Vag on it... Thanks
New Member
Is there a way to determine if it is faulty?
