ECU Problems
Wonder if someone might help shed a little light on a problem with my 98 A4 1.8TQM
Car started running rough and stumbling, as if in limp-home mode. No strange exhaust smells or colors, but it's almost as if a cylinder isn't firing, and it's running rough. However, it idles pretty damn near normal.
Hooked up my VAG-COM to find error code:
16989 P0605 Internal Control Module: ROM Test Error
I cleared it, but the car didn't appear to run any better, and the code came back.
Any experience with this or tips? I can't imagine it's good, but would this error cause the car to run like cr*p?
To complicate things, I'm in Auckland, New Zealand (moved here from Arizona last year), and am trying to determine if it's ECU before I contact Neuspeed to try to arrange a replacement.
The chip is a Neuspeed P-Chip T6K03, and has been in the car for almost a year before this began to happen.
Thanks!
Any lights lit up on the dashboard?
Check the archives for ignition amp and see if that sounds like the same thing.
