EGR valve stalling problem.
Old Mar 1, 2010 | 01:32 PM
Daltron's Avatar
Default EGR valve stalling problem.
I have a question.
recently I got a EGR insufficient flow check engine code and bought a new EGR valve. I installed the new EGR valve and went to run it. It ran good for a few minutes then started to dip when idling and eventually stalled. My check engine light is still on from before.
If I reset the computer to clear the codes will this fix my problem since the car may still think the bad part is still installed? What can I do?
Thanks
Old Mar 1, 2010 | 02:19 PM
AudiMick's Avatar
Originally Posted by Daltron
I have a question.
Thanks
You probably wasted your money on the EGR valve, 99% of the time it's your EGR passage that's blocked. Very common problem on the 12 valve cars.
Should have checked here first.
How are going to reset the computer, please don't say disconnect the battery. That won't do anything but remove all the learned info.Codes are not cleared by removing battery power, that's a requirement of OBD II.
Did you replace the gasket on the EGR and torque it correctly. A leak there will cause the car to stall.
Other than your ICV is dirty or disconnecting the battery lost all the throttle body/ ICV setup data.
S8code3
Q7 MK 1 Discussion
Jan 18, 2017 07:02 PM
vtraudt
Dec 6, 2011 08:55 AM
ivialb21
VAG-COM Discussion
Jul 18, 2008 04:59 PM
DennisStehlik
Audi 100 / A6 (C4 Platform)
Jul 8, 2003 09:00 PM
