Electrical Ghosts?
Old Oct 24, 2012 | 09:50 AM
UBERNOOB's Avatar
Default Electrical Ghosts?
Hey all. Very strange issue with my 99 B5 1.8T/AEB- under WOT i get random dash warning lights that flicker for a second. Does not happen any other time even over bumps/rough road. No codes. No power/voltage issues. Any ideas?
Thanks!
Old Oct 24, 2012 | 01:45 PM
mtroxel's Avatar
Stop the WOT first of all. I had a girlfriend's Volvo turb....did the same thing. Turned out the T-belt tensioner had gone limp and at WOT the cam timing was off enough that it started throwing all sorts of codes related to timing.
Old Oct 24, 2012 | 01:55 PM
ddillenger's Avatar
I know you said there are no voltage issues, but quite frankly I don't think you know what you're looking for (just because the car starts and runs and the gauge reads normal doesn't mean that the regulator isn't failing internally). Have a shop do a load test on the alternator, and battery.
When you say WOT, do you mean at ANY rpm, or just the higher RPM? Say if you go WOT at 1500rpm does the issue present itself?
Old Oct 26, 2012 | 10:17 AM
UBERNOOB's Avatar
Thanks for the input. Car has new battery and alternator/voltage regulator. No codes so I'm assuming that everything is in spec. I did replace the original 90 Amp alternator with a 120 Amp. Wondering if this could this cause issues?
Old Oct 26, 2012 | 10:22 AM
UBERNOOB's Avatar
And it usually occurs at lower RPMs- i.e. highway cruising at 60mph in 5th and then full throttle- lights flicker right away then go out. Does not seem to occur under WOT when accelerating from first gear through the RPM range.
Old Oct 29, 2012 | 12:45 AM
ddillenger's Avatar
Do you have any codes? Vagcom? I can give you a few measuring blocks to monitor if so...
Old Oct 29, 2012 | 12:53 PM
UBERNOOB's Avatar
No codes. I have access to Vagcom.
fmladineo
Q7 MK 1 Discussion
9
May 3, 2022 10:55 PM
bballfreak
9
Apr 14, 2019 06:59 PM
Kerry G
May 18, 2018 06:12 AM
anordin2
Feb 8, 2017 11:07 AM
alitech
Q7 MK 1 Discussion
Sep 30, 2015 03:29 PM
