Engine Cleaning
Old Apr 3, 2001 | 10:34 AM
Animagix's Avatar
New Member
Default Engine Cleaning
how do you guys clean under the hood? is it as simple as just rinsing? I'm assuming all the parts are waterproof. Because i'm about to clean it in a few seconds.
thanks<ul><li><a href="http://www16.brinkster.com/magicarc">http://www16.brinkster.com/magicarc</a</li></ul>
Old Apr 3, 2001 | 10:39 AM
DustysA4's Avatar
Default I clean it by...
putting the same stuff that I use on my dash(Meguirs stuff) on all the plastic containers, tubes, and engine covers. It makes them look brand new. I also use that on the weather stripping. I just use a damp cloth to clean any metal parts and other things that shouldn't have the vinyl stuff on it. I definately would not spray the motor with a water hose or anything like that if that is what your planning.
Old Apr 3, 2001 | 10:48 AM
Longwolf (Christian)'s Avatar
I use lots of simple green, let soak, wash with old rag, let dry, then armorall the black parts
Old Apr 3, 2001 | 10:52 AM
kennyc's Avatar
Default this is what I did,
cover up the battery, those plastic connectors on the right side of the engine, and anything else that has a wire coming out of it with plastic wrap, Then I just hose the engine down.
I have only did that once and just make sure you run the engine until it dried up completely. Since my engine is very clean now I just wipe the engine off with Vylnex on the plastic and rubber parts.
Old Apr 3, 2001 | 12:14 PM
dougie at work's Avatar
Junior Member
*gasp* not armor-all!
MrGoodbytes
Jun 6, 2007 01:27 PM
Kareem of Elise
Nov 7, 2004 04:27 PM
20vTurbo
Auto Detailing Discussion
12
Jun 27, 2003 06:06 AM
XC_Rider
Jun 25, 2002 09:27 AM
dbtong
Jul 9, 2001 07:12 PM
