Engine code 16500
My CEL is flashing. OBD-II code reads 16500. Engine Coolant Temp.Circ Range/Performance.
I'm hoping this is nothing more than the car telling me to change the coolant.
Anyone have an idea how serious or not serious this is?
Thanx.
You can drive the car until you fix it - it might just be a little inefficient on fuel until it's replaced.
Thanx a bunch. It's relieving to know it's not a big deal. I'll look into replacing it soon.
Thanx again.
Eddie
Hmmm, it lit up, I pulled over ... hooked up the OBD-II reader. It said 16500, and then I reset it.
If it comes up again, I'll make note if it's solid or flashing.
Thanx for the heads up.
But just in case, what's the difference between flashing and solid?
The forum archives have some good technical info if you want to do more diy work - they can take time to search through, but there are a lot of informative and helpful posts - you'll eventually want the link in your browser's toolbar
You can open BSK's FAQ thread via the hyperlink at the top left of the page in the forum name header.
