Engine Code on engine doesn't match code in trunk
Old Apr 8, 2003 | 07:50 PM
cpuckrun's Avatar
New Member
Default Engine Code on engine doesn't match code in trunk
I had to look up the engine code on my 99.5 1.8T to order some parts for the timing belt replacement. I found that the engine code on the engine block is AEB. The engine code on the sticker in the spare tire well of the trunk is APU.
Curious if anyone else has seen this before and why this might be? I bought this car used in 2000 from a dealer and the carfax report was clean.
Old Apr 8, 2003 | 08:01 PM
Audi2ptzero's Avatar
Elder Member
Default There are different codes for the block.
AEB is the code for the head. So APU might be the block code. You should be able to find it on the block too.
I was just told the other day that there are even 3 different engine codes for the 2000 but all 3 use the ATW head.
Old Apr 8, 2003 | 08:03 PM
Yippers®'s Avatar
Member
APU doesn't look like a valid engine code as near as I can tell. My wheel well tag says AEB.
Old Apr 8, 2003 | 08:05 PM
Yippers®'s Avatar
Member
Default Found this for 1.8 2000 MY engine .. interesting
<ul><li><a href="http://www.theracersgroup.com/applications.html">http://www.theracersgroup.com/applications.html</a</li></ul>
Old Apr 8, 2003 | 08:23 PM
Elder Member
Default Funny thing is
juan brought this up the other day while both of us were at DRS.
p8ntball_89
12v V6 Discussion
Sep 2, 2022 05:36 AM
Audi2.8L
Mar 8, 2010 07:58 PM
Audi2.8L
Mar 8, 2010 07:56 PM
chris20vT
Mar 9, 2003 08:45 PM
süpercüp
Aug 25, 2002 12:19 AM
