Engine idle problem
Old Apr 12, 2006 | 12:52 PM
DVW's Avatar
DVW
New Member
Default Engine idle problem
Hello,I hope someone can help me. I have a 1996 A4 2.8l and i have some idle problems. When starting the car in cold weather like below -20celcius I have to push on the gas pedal until the engine warms up and then it runs fine. Also now in warmer temps the car starts like a new car but,when i hit town the engine RPM drops to about 2-300rpm and fluctuates up and down without stalling.The throttle body was clened, the idle valve was checked and cleaned and i also changed the temp sensor.
Can someone help me because I love that car but I'm getting a little bit tired!!!
Thanks Mark
Old Apr 12, 2006 | 01:01 PM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
You probably need to do a TBA. Now, before you ask me what a TBA is, search please. Its easy.
Old Apr 12, 2006 | 01:33 PM
AudiMick's Avatar
Default Did you replace the vacuum lines? How did you clean the throttle body?
On the 12valve there are couple that can leak. If you haven't replaced any of them you are way overdue.
The only way to clean the throttle body correctly is remove it. Spraying gumout around while its still attached is worthless.
Old Apr 12, 2006 | 02:17 PM
qfrog Ti20's Avatar
Default um the 12v has an idle control motor
I dont think there is a TBA function for the MMS-411 ecm.
mattarios2
Dec 13, 2019 04:16 PM
Danielsan16974
Audi A3 / S3 / RS 3
Jul 16, 2010 12:40 AM
forced induxion
Mar 14, 2006 09:03 AM
dblum2
Audi 100 / A6 (C4 Platform)
Apr 18, 2005 09:31 AM
reign1104
Jan 11, 2005 12:40 PM
