Engine idle RPM drops when using windows or AC
Old Aug 9, 2011 | 04:43 AM
Mumawalde's Avatar
Default Engine idle RPM drops when using windows or AC
I've searched this topic for a while but haven't had any luck finding anything.
My '01 A4 1.8T has done this since I purchased it (used)
When the car is idling and I roll the windows down, the engine drops in rpm. Almost like the electrical load causes the engine to slow. I really don't think that window motors should do that. It does it on all 4 windows, and it's mostly pronounced once the windows is all the way up or down and the motor stalls.
Also, putting the AC on causes the idle to drop pretty significantly as well; to the point where I keep my foot on the gas just to keep it up to normal.
Any ideas?
Thanks
Old Aug 9, 2011 | 10:04 AM
turbo510's Avatar
Sounds like the throttle motor isn't opening the throttle plate enough to compensate.
Old Aug 15, 2011 | 09:59 AM
Mumawalde's Avatar
How do I check the throttle motor? Is there a procedure posted somewhere?
Old Aug 15, 2011 | 11:08 AM
4Driver4's Avatar
Tech Guru
Tech Guru
VAG-COM is your friend.
Old May 16, 2012 | 03:42 PM
Mumawalde's Avatar
Default is the throttle motor in the throttle body?
I still have this problem. I tried tuning it with VAG-COM, nothing..
I think it's time to change the motor. Is it part of the throttle body?
Also, will a swap out require VAG-COM intervention or will the ECU figure out what's going on?
Old May 17, 2012 | 06:50 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Part of the throttle body. Changing it will require a TBA.
Old May 17, 2012 | 08:35 AM
Mumawalde's Avatar
Default how about cleaning the throttle body
does anyone have any experience with just cleaning it rather than changing it for this problem? Do they get gummed up with junk often?
Old May 17, 2012 | 11:31 AM
Reggie's Avatar
Club AutoUnion
25 Year Member
Before you do that try a can of BG44K first - let the fuel system get cleaned out and eliminate that issue.
krsmith
Mar 20, 2011 06:34 AM
225GUY
Sep 1, 2008 10:07 AM
Carguy427
May 13, 2003 11:08 PM
JRS4
May 4, 2001 11:24 AM
Jimmy D
Jan 21, 2000 11:47 AM
