engine jerk when the car is cold?
Old Feb 1, 2000 | 05:41 PM
BChan
Guest
Posts: n/a
Default engine jerk when the car is cold?
I own a 1999.5 1.8T QMS. When the car is cold, particularly now in the winter, is anyone experiencing an engine jerk when accerlerating after starting the engine up? I only have 10K miles on the car.... damn.
Old Feb 1, 2000 | 05:54 PM
Alex L
Guest
Posts: n/a
Default I swear I had that this morning....(nt)
nt
Old Feb 1, 2000 | 06:18 PM
CaryB
Guest
Posts: n/a
Default This is normal. Here's what I was told....
I used to have a 98 Jetta GT 2.0L that did the same thing. VW service rep said that VW/Audis run rich until warmed up. The only way to avoid this is to drive it in a higher gear than normal (lower RPM) or let it warm up a little longer. I sometimes let my A4 warm up for 10 min when its in the high 20's and low 30's outside. Hope this helps.
CaryB
99 A4 1.8T
Old Feb 1, 2000 | 06:29 PM
BChan
Guest
Posts: n/a
Default Re: This is normal. Here's what I was told....
Thanks! Do you experience this anymore with your 1.8T or have you eliminated the problem by letting it warm up? Confused b/c the manual says it's not necessary to warm up the engine....
Old Feb 1, 2000 | 06:41 PM
CaryB
Guest
Posts: n/a
Yes, I can still experience it only when engine is cold. Mine is about 1 year old.
Old Feb 1, 2000 | 06:47 PM
CaryB
Guest
Posts: n/a
Default More info....
My A4 will not idle at a higher RPM as other manufacturers do, like a choke would on an older car. I let it warm up no matter what. Once it is warm it runs fine even when very cold outside (saw 28 degrees on the trip computer) here in South Texas. Just let your A4 warm up in the future and you should be OK. Remember even when the water temp is already up, the oil temp is still low on cold days. Engine is not happy until warmed up.
Old Feb 1, 2000 | 07:09 PM
brian
Guest
Posts: n/a
Default Re: engine jerk when the car is cold?
i don't experience a jerk but i did post a message awhile ago asking if anyone has a whistling sound coming from the engine when cold temps are present. i didn't get any good answers but i am having the car checked by audi 2 wks from now. does your car make a noise or just a jerk? i have found if i let my car warm up it does lessen the noise but i dont always have the time to warm it up. unfortunately the sound is miserable. how come other cars don't do this?
brian
98 A41.8TQM
Old Feb 1, 2000 | 09:43 PM
AT
Guest
Posts: n/a
28 deg = very cold. chuckling to myself here in minnesota.
Old Feb 1, 2000 | 10:39 PM
Warm in Fla
Guest
Posts: n/a
We're chuckling at you too. ;-) (nt)
Old Feb 1, 2000 | 11:12 PM
Drew
Guest
Posts: n/a
i think that 10 minutes is a little too long. might give you a tap. (nt)
