engine knock
Old Oct 15, 1999 | 11:37 AM
doug
Guest
Posts: n/a
Default engine knock
I apologize if this has been addressed in the past. I (well, my wife) currently lease an 97 A4 2.8. I have noticed what sounds like a valve knock "or ping" when accelerating. I don't know what it is, but it sounds like a valve ping. I've taken it to the dealer and they stated it was low on oil. This is not the case. When I got the car back, it still made the pinging sound. All be it, a little better. I don't really care, cause we are returning it soon with a A6 2.8 in mind.
So what gives….
My car is at the dealer (not the audi, another car). They gave me a loaner A4 2.8 (looks like a 99). Guess what? It has a same pinging sound. I understand the A6 has the same motor. IS this true? Should I be concerned this may be a chronic problem? Thanks in advance.
-doug
Old Oct 15, 1999 | 12:29 PM
RickM
Guest
Posts: n/a
My '97 A6 wagon (same engine as yours) doesn't knock, never has ...are you using premium fuel?
Old Oct 15, 1999 | 01:47 PM
ErikR
Guest
Posts: n/a
Default Re: engine knock/ring
Are you sure it's knock? With the loaner, put it in second gear and stomp on it (windows down). Does it sound like marbles in a coffee can? Which then stops if you let off the throttle a little bit? Rev it to almost redline in second gear, only applying the throttle slowly. What noises does it make then?
There are a number of parts that can ring at higher revs, but only knock is bad for the car.
richardi
Nov 6, 2018 06:45 AM
botl435
Apr 2, 2017 03:37 AM
whamalek
A6 (C7 Platform) Discussion
Mar 3, 2017 11:47 AM
DesmoTesta
9
Feb 16, 2008 08:44 AM
DoraBugA6
Mar 17, 2004 02:08 PM
