Engine Overheating . . . need advice. . .
Old May 26, 2007 | 10:35 AM
BiggEasy's Avatar
New Member
Default Engine Overheating . . . need advice. . .
My engine has been slowly increasing temp until now it runs one line to the right of center. Brought it to a shop some months ago and $1300 only bought me a new fan relay switch and some tiny gaskets around some of the hoses. . .
Overheating came back. I decided to drain and replace the radiator. (Back in 01 I had to replace a radiator for the same type of condition.) Well new radiator is installed and system bled but overheating is still occuring.
Based upon my searches I have three possible culprits 1) T-stat 2) Water Pump 3) head gasket. I am tempted to change the t-belt and just replace t-stat and pump at same time. However, the upper and lower hoses on the radiator are hot indicating that coolant is flowing in and out. Also, the needle doesn't go all the way to H but just to the first line past center.
Any thoughts from you expert trouble shooters out there. . .
FYI. . . I'm at 140k had water pump and timing belt done at 90k. After 9 years I'm about to call the scrap yard. . . to pick it up.
Bigg Easy
98.5 A4
Old May 26, 2007 | 11:24 AM
Neo1130's Avatar
Junior Member
Owners manual states as long as the light doesn't come on, you are fine...
Old May 26, 2007 | 12:10 PM
tobin's Avatar
Default Re: Engine Overheating
When your temp guage is past center, is your elecric fan (the one on the left when looking at the engine) running? Both fans should be running at full speed.
Old May 26, 2007 | 07:04 PM
BiggEasy's Avatar
New Member
Default No its not. However, it runs when the AC is on. . .
And the temp doesn't go down any lower when the AC is on. . .
Old May 26, 2007 | 07:31 PM
tobin's Avatar
Default OK so that narrows it down a little.
As soon as the temp guage goes past half, the fan should turn on, and run on high speed until the temp returns to normal. It will automatically do this so that you won't notice a fluctuation in the guage at all. What engine and year are you?
There is a fan sensor/switch in the lower area of the radiator (location varies) which craps out over time. You should start by replacing this. They are pretty cheap but it requires that you drain the coolant.
If that doesn't work, there are 2 electric fan relays, and a few other components which can be at fault. I would start by replacing the fan switch and coolant (be sure to bleed the system afterwords). Search for "electric fan" and filter for posts by ModifiedA4. He is the electric fan guru in my opinion and helped my solve the problems I had on my 98 2.8.
Keeghan
Aug 23, 2010 04:43 PM
mtnxbiker
Apr 6, 2006 08:51 AM
thadeak
Jan 11, 2004 02:33 PM
Steve_Ag Arrow
Oct 14, 2003 06:23 AM
odelay12v
Jun 20, 2002 10:33 PM
