Engine Problem...1.8t Experts Pls. Help!!?
Old Aug 24, 2006 | 03:28 AM
pinoykool's Avatar
New Member
Default Engine Problem...1.8t Experts Pls. Help!!?
I have this Weird problem on my 98 1.8t A4 Quattro. I was driving on 95 when all of a sudden the engine went Shut Down. I tried starting it again while I was waiting for the Tow Truck and I noticed that It was just the Outside Belt the was Turning and there are no Crank on the Engine while I was Cranking it. Anyways at first I thought it was just my Timing Belt that has Finally Given Up. So I check the Timing Belt but I saw that it still has its Tension and While looking at it, Again I tried to Crank Up the Engine and I Confirmed that it was just the Outside belt that was turning and Not my Timing Belt. Anyone Had or Been thru the same problem I am having?? Pls. Help 1.8t Expert. Thanks Alot!!
Old Aug 24, 2006 | 03:53 AM
nunya's Avatar
The timing belt is under an engine cover, you cant see it from just popping the hood.
Old Aug 24, 2006 | 04:00 AM
Joey T
Guest
Posts: n/a
Miles, when was the belt done,clarify if you actually had the covers off to see the belt.
Old Aug 24, 2006 | 06:43 AM
Vic995's Avatar
Junior Member
Default The crank drives all belts, so if the outside belt turns but not the TB, and the TB...
tension and belt teeth look okay, then it defies logic.
Old Aug 24, 2006 | 09:47 AM
picnicbob's Avatar
Default if the TB teeth sheared off at the crank it could still have tension but not turn.
how many miles since the belt was changed?
Old Aug 24, 2006 | 09:51 AM
TmS4's Avatar
sounds like stripped teeth on the TB, the is the most common type of failure
Old Aug 24, 2006 | 08:48 PM
BJC::wokka wokka's Avatar
Elder Member
Default Yup, happened to me a couple of months ago....sheered off about 15 or so teeth of the timing belt.
good luck, if you fix it yourself you can keep it under $2000 fairly easy. let me know if you have any questions.
aquaman38
TT (Mk2) Discussion
Jun 28, 2019 06:15 AM
abqhudson
A4 (B7 Platform) Discussion
Jan 5, 2013 04:38 PM
GreekTTCharlie
Apr 24, 2008 03:26 PM
owen
Sep 24, 2001 07:54 AM
Shawn99/30V
Dec 20, 2000 05:28 AM
