engine/tranny problem ?? HELP..
Old Oct 29, 2001 | 03:27 PM
Master T's Avatar
Default engine/tranny problem ?? HELP..
I have a 1997 A4 1.8TQA with an annoying problem...Just as I come to a complete stop at a light or whatever the engine gives a shake/vibration like its going to stall but never does (it is very subtle and it is really only the driver that can feel it). Looking at the tach the RPM's never drop below normal idle. Is that an engine issue or a tranny issue. Any information would be great.
Thanks
Master T
Old Oct 29, 2001 | 03:28 PM
Skene @ PES Tuning's Avatar
Elder Member
possibly time to replace your motor mounts..
Old Oct 29, 2001 | 03:32 PM
Master T's Avatar
Default Re: possibly time to replace your motor mounts..
There is no other time when there is a strange vibration unless I come to dead stop....that coul dbe the motor mounts ??
Thanks
M
Old Oct 29, 2001 | 03:37 PM
Elder Member
Default well lets think about it... your coming to a stop... your engine is pretty much being thrown...
from the back to the front... you have to remember... you accelerate.. you yourself gets pushed into the seat? correct? when you decelerate.. your body is eased off from the seat.... same thing with an engine.. the mounts hold the engine like a seatbelt.. it might not hold you in place when your being pushed back.. but when you get lunged forward. and you also have to remember that it is holding up an engine at the same time.. so could it be possible.. yes it could be... if you want a definate.. i couldnt tell you.. have a friend of yours press on the gas pedal while you watch your engine movement.. if you see a lot of play.. yes it is time.. if it doesn't move much... then you might be ok and you have a larger problem. most engine/tranny problems occur from bad mounts. then comes from the way you drive your car.
Old Oct 29, 2001 | 03:44 PM
Master T's Avatar
Default Re: well lets think about it... your coming to a stop... your engine is pretty much being thrown...
How much is it for new mounts plus labour from an Audi dealer ?? Expensive ??
Thanks
Master T
Old Oct 29, 2001 | 03:46 PM
Elder Member
Default dont know... would i take it to an Audi dealership to do the work... probably not..
buy the parts from Audi... while your there ask how much it would cost.. it wont hurt to ask.
Old Oct 29, 2001 | 04:11 PM
twoquattros's Avatar
Junior Member
Default cheking for bad motor mounts more inside
get somebody to sit on the drivers seat, make sure the car is parked (hand brake up)have the person put the car in first gear and release the cluch slowly the car wont move cause the parking brake is on, but the engine should swing a bit, with the hood open u should see how much the engine swings, if it swings more than two inchs than u have a defective engine mount.oh yea do the same thing in reverse.
hope this helps
OzzyLime
Apr 14, 2011 06:33 PM
Mr.88-80Q
Nov 3, 2004 06:04 AM
SilverB
May 8, 2004 04:24 PM
Mr.D-'97 A4q 12v
12v V6 Discussion
14
Nov 10, 2003 02:00 PM
sbellan
Feb 3, 2003 07:56 PM
