engine update
Old Mar 10, 2006 | 08:23 AM
BOOSTD's Avatar
Elder Member
Default engine update
Riverside pulled the head and it was just what they suspected...heavy deposits on a few valves (up to 1mm) that wouldn't allow them to seat properly. Timing belt was fine.
Now I'd like to ask for your help. Please read the following link. Some of you old schoolers will remember Brandon but most of you newer guys won't. He doesn't read AW anymore, but we'd like to keep this a surprise. A few of us have the right contacts and will get this into the right hands.
Your support is greatly appreciated.<ul><li><a href="http://www.petitiononline.com/b1b/petition.html">http://www.petitiononline.com/b1b/petition.html</a</li></ul>
Old Mar 10, 2006 | 08:24 AM
Solaris's Avatar
AudiWorld Uber User
carbon deposits? What could have prevented it?
Old Mar 10, 2006 | 08:34 AM
BOOSTD's Avatar
Elder Member
Default more "Italian tune-up" driving
however my clutch has been on the way out for a while so I've been taking it easy. Most of my driving is highway miles too. They're putting in my new clutch and TB/water pump while they're in there.
Old Mar 10, 2006 | 08:41 AM
Solaris's Avatar
AudiWorld Uber User
you mean not driving the car hard when it was built to be driven hard?
Old Mar 10, 2006 | 08:44 AM
BOOSTD's Avatar
Elder Member
Default correct
since the clutch has been slipping badly I haven't been able to wail on it hard for a while now, which helps to blow out deposits.
Old Mar 10, 2006 | 09:55 AM
coocoomike's Avatar
oh man, i didnt know about B1B
Old Mar 10, 2006 | 10:10 AM
RKA's Avatar
RKA
AudiWorld Uber User
Default Wow...glad they got it fixed...but that really sucks!
As far as B1B...sometime's life just isn't fair. That's for posting that link.
Old Mar 10, 2006 | 12:21 PM
KurtW's Avatar
Default Several of us discovered this problem a couple of years ago.....
.....with our PES superchargers, which seem to accellerate the problem. The AoA solution of adding a fuel cleaner doesn't really address the problem, as the injectors only hit the center intake valve of each cylinder.
Oour solution was to run a solvent throught the entire plenum by drawing the solution in at the throttle body. I think Rob Andrews has a write-up on his site (www.robsaudiworld.com or something like that) There's a link on this site to his. The downside is that you WILL throw CELs like crazy, which must be cleared afterwards. The best solution to use is called "Seafoam" from several auto parts stores.
I did a write-up of sorts on the superchargedaudi.com site, which is currently down for some reason. If it comes back up, search under my screen name - KurtW, or under "cleaning".
Update: the superchargedaudi.com site is back up, now scaudi.com<ul><li><a href="http://www.scaudi.com/">http://www.scaudi.com/</a</li></ul>
 Michael S. Palmer
klann187
Oct 15, 2010 08:43 AM
etaudi
Audi allroad
13
Nov 30, 2009 08:43 PM
QWKDTSN ~ TURBO-WGN
21
Apr 9, 2008 07:51 AM
myfirstimport
Jul 25, 2005 05:03 PM
Bryans12v
Mar 9, 2003 05:02 PM
