Error Code 17887 - Found a Boost Leak
Old Jan 22, 2006 | 07:11 PM
Diavan's Avatar
Default Error Code 17887 - Found a Boost Leak
<center><img src="http://www.audiforums.com/upfiles/8628/7D8D94E0FDFC47ED83BD1970898E5D58.jpg"></center><p>The code keeps coming back
17887 - Brake boost Vacuum System Mechanical Failure
I've found many posts about this code talking about the boost leaks in the hose (or near the hose) that go thru the firewall.
So finally I found a boost leak today, in one of the hose connections, just behind the FPR.
The arrow in the picture shows where the bubbles were coming from when I used soap water.
I don't think the Part A is bad. I am looking to get the part number for B (Hose).
Can anyone could help me getting the part numbers for the leaked hose (B).
Really appreciate that.
Thanks ya'all.
Old Jan 22, 2006 | 07:13 PM
Nate (ETKA+Scumbag)'s Avatar
Keeper of the Cash
Tech Guru
Scroll down.
Old Jan 22, 2006 | 07:15 PM
Silver Streakin''s Avatar
Member
it's all one part and the part number is on it.
Old Jan 22, 2006 | 07:45 PM
Kolt45's Avatar
New Member
Default I had the same leak, I had to replace part A
You can get the suction pump (part A) from ECS for around $23, it's a pretty common part to replace.<ul><li><a href="https://forums.audiworld.com/a4/msgs/2432648.phtml">https://forums.audiworld.com/a4/msgs/2432648.phtml</a</li></ul>
Old Jan 22, 2006 | 08:03 PM
Diavan's Avatar
Default Re: I had the same leak, I had to replace part A
Kolt, did u change the Hose ... Part (B)?
Old Jan 22, 2006 | 08:17 PM
Kolt45's Avatar
New Member
Default naw, just part A
I found it was a source of a boost leak.
Old Jan 22, 2006 | 08:52 PM
Diavan's Avatar
Default Re: naw, just part A
Dangit. Its one cramped up space. I hope I don't mess up the other connected hoses. Any tips ?
Old Jan 22, 2006 | 09:25 PM
Kolt45's Avatar
New Member
Default Your right, it wasn't super easy, take your time....
It's way back in the engine bay and removing the factory hose clamps isn't always fun. Just one at a time. It might help to take "L" hose off with the suction pump, after you remove the other hose clamps. I can advise to be careful, there a plastic one way valve on top that can break. There like $18 at the dealer, so just take your time. Pressure test it all again with soap (like you did the first time) when you're all done.
 Pouria Savadkouei
 Michael S. Palmer
supersTTar
Oct 8, 2005 01:29 AM
AKS4
Sep 13, 2005 08:49 PM
/APOOOORGUY - OOOOA4
Mar 15, 2004 06:30 PM
