Error Code for Fuel System problem
Old Mar 20, 2004 | 05:48 PM
pat33's Avatar
Default Error Code for Fuel System problem
I have a problem with the Fuel delivery system, my Motor gone in cut off mode when I accelerate too fast, it seem that the car missed some Gaz.
My car is a 1999.5 A4 1.8T QM with GIAC Chip, AWE Exhaust, Test Pipe and Hyperboost Adj.DV. I installed a O2 Sensor Simulator(MIL Eliminators), is it possible that this simulator cause me more problems ?
Here is the code I've got:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
16524 - OXYGEN(LAMBDA) SENSOR B1 S2:NO ACTIVITY
P0140 - 35-00 - -
Thanks to help
Patrick
<img src="http://pictureposter.audiworld.com/19727/vag-com_codes.jpg">
<img src="http://pictureposter.audiworld.com/19727/vag-com_codes-3.jpg">
<img src="http://pictureposter.audiworld.com/19727/vag-com_codes-4.jpg">
<img src="http://pictureposter.audiworld.com/19727/vag-com_codes-5.jpg">
Old Mar 20, 2004 | 06:03 PM
ModifiedA4's Avatar
Banned
Default hey where's your desktop background from?
also, you have mods that mess with the cat system and you have an o2 sensor dtc? coincidence? i think not.
Old Mar 20, 2004 | 06:08 PM
Ritz's Avatar
Default Re: Error Code for Fuel System problem
Well, the system is telling you that it hasn't heard from that O2 sensor in a while. Without a signal from the sensor, the computer can't set the fuel trim properly since it needs to know the current lean/rich situation down south at the O2 sensor. Check to make sure the sensor is still connected. If it is, it's bad and should be replaced. After you replace it, clear the fuel trim code and drive the car for a while, then check the codes again. The fuel trim code will probably not reappear.
Cheers,
Old Mar 20, 2004 | 08:56 PM
201-A4's Avatar
Junior Member
Are you using the MIL eliminator on the 1st or 2nd sensor?
Aphex350
Oct 29, 2010 04:35 PM
suburbanscumbag
Mar 31, 2010 10:22 AM
silvr12v
12v V6 Discussion
May 24, 2007 02:46 AM
pat33
Mar 22, 2004 10:37 AM
pat33
Mar 21, 2004 10:28 PM
