Error codes error codes...
Component and/or Version: 1.8L R4/5VT G 0002
Software Coding: 16201
Work Shop Code: WSC 06435
2 Faults Found:
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-10 - - - Intermittent
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
Does this mean anything to antbody?
I also logged my drive from home to work, but then again I don't know the good value ranges.
Any info is appreciated.
And yes I'll look the codes up from the manual, if I can find the right manual to look it up from.
I just don't feel like going through a propane/oscilloscope test right now.
Unfortunately, DTCs don't have time stamps. Because of this you never know if you pulled a fresh DTC or a three month old one. Thus if in doubt (meaning you don't see an obvious problem) it's OK to clear an INTERMITTENT DTC and check back in a short while to se if it reappears.
In your case since the DTC didn't reappear it's OK for now. I'd check it again in 2 weeks or so.
