Estimate on replacing springs?
Theoretically, if the rear was overloaded and it over-compressed the spring, changing the ride-height some, wouldn't that require a replacement? Ive only had the car for 1 month and not sure how it was treated before i got it.
Check the top of the wheel arch to the floor on all four corners. Typically they should be less than 10mm height difference side to side. They are never perfect.
Some people like to replace with coil-overs because they can get identical ride height.
Does your car have black shocks or red shocks? Red means original factory sport suspension which is 20mm lower than stock.
I think the H+R s are 31mm lower than stock.
