External temperature sensor failure
Example behavior - when I start the car in my garage, and it's probably 60 degrees outside, the outside temp shows as 20 deg F. While driving the car, it will drop to as low as -58 deg F, and then slowly cycle up to the current temp (slowly == over about 15 minutes).
Trying to use the A/C when the external temp sensor reads below zero doesn't work.
Anyone?
I haven't felt the need to have mine fixed, Audi said it wasn't covered under warranty and it would be about $300.
