Foglight problem...
Old Oct 21, 2003 | 09:09 PM
Zodiak's Avatar
Default Foglight problem...
I usually have my foglights on whenever I am using my headlights. However recently,
when I turn on the high beams the fogs go off (the green light on the fog button goes out) and they don't come back on when I turn off the high beams. This will sometimes happen if I even lightly tap the turn signal stalk on the steering column (the foglights will go out sometimes when the stalk springs back after I complete a turn). You can actually hear the switch go off behind the glove box (where the switch module is located on MY99.5s).
Does anyone else have this problem?
I had my Ignition Switch replaced last week (the problem started after that) did they F-up the wiring?
If it's the foglight module, can I fix it myself? the part cost $120 from the stealership.
Any help is appreciated
Old Oct 21, 2003 | 09:14 PM
shrtbus(w/ cq)'s Avatar
Default Foglights don't work when the high beams are on...
that is unless you rewire it...check the tech section...
Old Oct 21, 2003 | 09:15 PM
Zed 2.0's Avatar
that isn't his problem
Old Oct 21, 2003 | 09:17 PM
[tri]liament's Avatar
i dunno what's wrong, but you can do the independent fog mod and see if that helps
Old Oct 21, 2003 | 09:25 PM
Zodiak's Avatar
Default Your Greddy is a little tilted, some electrical tape at the top should fix that....anyway, (more)
I think it has to do with a connection at the base of the turn signal stalk, since I know they were working in that area when they replaced the ignition switch, and I didn't have the problem until I got it back from them. I will call them tomorrow.
But I also plan on doing the foglight mod this weekend so maybe that will help too.
Old Oct 21, 2003 | 09:32 PM
Default the greddy isn't tilted, though it is sticking out more on the right side in the picture
it has since been fixed, no need for more tape.
Meny
Jul 7, 2015 12:39 PM
tetraelement
10
Nov 17, 2006 07:16 AM
shrtbus(w/ cq)
May 31, 2004 09:02 PM
Casablanca Avant
Dec 3, 2003 03:58 AM
jfabes
Feb 6, 2001 12:01 PM
