Fuel filter replacement tips?
Old Dec 19, 2006 | 02:15 PM
austinado16's Avatar
Default Fuel filter replacement tips?
Hi All,
I'm usually over on the C4-A6 forum where fuel filter replacement is a 5min job, but.....
I'm working on a 98 A4 Quattro and shocked to discover the location of the filter. Who's joke is that?
Anyway, was reading in your archives and found that some of you cut the bolt that holds the pinch strap, other's take the tank down.
I don't see how the tank can come down much since it strattles the rear diff and axles in 3 directions. I removed the 4 bolts from the main tank area on the filter side and that only allowed the tank to move down about an inch...then it starts hitting right inner CV joint shield.
So, could someone give me some details?
Thanks!
Old Dec 19, 2006 | 02:24 PM
OldManTan's Avatar
Junior Member
Default Have you read the tech article?
It is located in the engine section. <a href="https://www.audiworld.com/tech/eng.html">link</a>
Old Dec 19, 2006 | 02:41 PM
bitjockey (bum)'s Avatar
Member
Yup. With a lift and a properly sized board, its a 30 minute job max.
Old Dec 19, 2006 | 02:44 PM
You guys saved the day!!!! Thanks a million!!
Old Dec 19, 2006 | 02:48 PM
Longwolf (Christian)'s Avatar
Default I need to do the FF on my 1.8tq, and on the quattros it looks like a nightmare of a job.
I need to do it eventually.....I even have the filter.
I asked a tech at my local dealer if he would do it on the side for me....he said NO WAY, THAT JOB SUCKS!
Old Dec 19, 2006 | 02:56 PM
shawfm's Avatar
Default read the tech article. It helps I did my '00 1.8t Q-tip and '01 2.8Q-tip without any problems.
I agree that it can be done in 30 minutes. I also believe that this job can frustrate anyone if they are not prepared.
Old Dec 19, 2006 | 03:23 PM
Member
Default Its REALLY not that bad, I don't understand all the problems people have.
With a lift and the proper socket, its seriously a 30 minute job.
I'd change fuel filters all day long before I do a clutch on this bitch again.
Old Dec 19, 2006 | 03:39 PM
OldManTan's Avatar
Junior Member
Cool. BTW - I check all the tech articles every few weeks just to remind myself what's in there.
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 19, 2006 | 04:21 PM
Default Update: All done, 30min total. Can't thank you guys enough.
That's one dialed in tech article section you guys are sporting! I really appreciate all the help and speed of the replys.
And now I return to the world of 5min fuel filter changes and 1hr timing belt jobs. *snicker-snicker*
Happy Holidays!!!
Old Dec 19, 2006 | 05:33 PM
Member
Congrats! Where do you live in SLO? I work in Grover...
